Inventor Forum
Please Help! - convert .dwg to .stp and .igs
17 REPLIES 17
Message 1 of 18
5334 Views, 17 Replies
Hi.
I have tried downloading and installing the Inventor LT trial twice now but for some reason I keep getting errors and it won't run. Could someone please convert the attached .dwg files to both .stp and .igs file format? Each drawing has just a single solid in it so hopefully it won't be much trouble.
Any help is greatly appreciated!!!
Thanks!
(see following post for second file)
17 REPLIES 17
Message 2 of 18
2nd file to convert
Message 3 of 18
> file format?
Here are igs files.
The original files are very coarse meshes, anyway...
M.
AIS 11 SP4
Pentium 4 3 GHz - 2 GB RAM
NVIDIA Quadro 330 6.14.10.9136
Message 4 of 18
Thanks so much Marco for converting them to .igs. And yes they do look a little 'crude' but they are supposed to.Thanks again!
To others reading this thread, I still need to get the files converted to .stp format so if anyone can help out that would be great!
Message 5 of 18
VChampDK
Here you go.
Peer
Peer
Iv2018/Vault Professional 2018
Lenovo ThinkStation P720
Intel Xeon Gold 5122 - 3.6GHZ
32GB RAM - Win10/64Bit
Lenovo Thinkvision 27"; 2560 x 1440
nVidia Quadro P2000 - 5GB 25.21.14.1771
3Dconnexion SpaceNavigator 10.5.4
Message 6 of 18
Please tell me what I need to be able to convert dwg to either .stp or .igs?
James.
Message 7 of 18
JDMather
Autodesk Inventor will do the job.
Message 8 of 18
AutoCAD Mechanical for 2D IGES works fine.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
AIP 2008 SP3, AIP 2009-SP2, IV2010 ProPcCillin AV
AMD 64 x2 3.0 Ghz, 8GB RAM GeForce 9800GT 512MB
XP Pro SP3, XP Pro64 SP2, Windows XP Silver Theme
http://teknigroup.com
Message 9 of 18
Thank You .
I don't have Inventor. I was hoping ther would be some kind of plug in...
Message 10 of 18
iDS!
MDT (Mechanical Desktop) will do this as well 🙂
commands:
igesin
igesout
stpin
stpout
Message 11 of 18
in reply to: iDS!
Hi, i have the same problem and was wondering if anybody would be kind enough to convert this drawing to an iges and step format, its much appreciated
Message 12 of 18
Can you please convert this file to *.stp?
Thank you very much!
Message 13 of 18
JDMather
With free Inventor Fusion - you can now do the conversion yourself.
http://labs.autodesk.com
Much of your geometry fails quality checks and looks more complicated than it needs to be.
Message 14 of 18
hi i will someone help to convert this file in .stp and .igs thank you
Message 15 of 18
WHolzwarth
Here's a STEP, exported out of ACAD Mechanical 2014.
Walter
Walter Holzwarth
Message 16 of 18
hi i would need help to convert those 2 pieces in stp.  could u do it for me please
Message 17 of 18
hi anybody could convert those 2 dwg into stp
thanks
Message 18 of 18
WHolzwarth
No big deal, Steve
- Open DWGs in ACADM
- Export them as STEP
- See result
Walter
Walter Holzwarth
