Inventor Forum
Please Help: Changing inches to mm
5 REPLIES 5
robzam123
380 Views, 5 Replies
Is it possible to change the units of some imported part without changing the dimensions? I have imported an assembly from an external source but had the units settings as inches. However I want to change them to mm.
For example: I want to change a dimension of 55in to 55mm.
Thanks for the help.
Best Wishes
5 REPLIES 5
in reply to: robzam123
Look at the options when you are importing, I think this is where you need to change it.
robmatthews
If you only have a few that you need to change, do this. Otherwise, I use a VBA routine to automate the process, code  below.
Sub SetAsMetric()
' Written 2010 by Rob Matthews (c)
'Simplified 16-04-2012
On Error Resume Next
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
    oDoc.UnitsOfMeasure.LengthDisplayPrecision = 5
    oDoc.UnitsOfMeasure.AngleDisplayPrecision = 5
    oDoc.UnitsOfMeasure.LengthUnits = kMillimeterLengthUnits
    oDoc.UnitsOfMeasure.MassUnits = kKilogramMassUnits
    oDoc.Update
Set oDoc = Nothing
End Sub
This is my signature, not part of my post.
robzam123
in reply to: robmatthews
Robert
robmatthews
You're welcome. Did it answer your question? If so, please mark as "solution".
KyleAutoDesk
How do you change it from inches to millimeters but keep the numbers the same (i.e. 120 inches to 120 millimeters)?
