Hello. I have 2 problems:
1. created a turbine whose blades are made from some planes that I applied thicken offset command. I applied circular pattern to multiply the blade around center point but i get too many planes and i must to make invisible each one. How can i make invisible all planes in the same time.
2. After i make them invisibile i exit from that part but when i start that part again or when i place it in an assembly all planes are visible. What should i do to make them invisible for ever.
Solved by CCarreiras. Go to Solution.
Hi!
You are talking about planes or surfaces?
To hide the planes, go to tab View -> Object Visibility, and deselect "All work features"
If you want to hide the surfaces, in the browser, open the folder "surfaces", select all with select+ control key, or shift Key, like selecting files in windows and RMB and deselect Visibility. Do this before place the part in one assembly.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
You did not even need to create ExtrusionSrf1 - you could have Trimmed the LoftSrf1 directly with Sketch6.
