Inventor Forum
Placing Centerline on an arc
2 REPLIES 2
2235 Views, 2 Replies
Is it Possible to place a centerline on a drawing that has an arc or radius?
(example: any dia. bar with a 90deg. bend or any deg. bend.) I want the CL
to follow the bend or arc that is placed not just straight lines horizontal
or vertical. I can get centerlines on my drawing as long as the lines I'm
working with are parallel or holes. I hope this is enough information.
Thanks Josh
2 REPLIES 2
If I understand correct. You have to do use a center line bisector pick the two arc lines
Yes that worked.  I used all of the tools
except that one when I was trying.  thanks
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
If
arc lines
