When i place a part from content center, its "stock number" is format default like this: "L25x25x4" (it's structural shapes angles).
So, i want to change this default format: "L25x25x4" wil be change to "T L25x25x4" when i place a new one.
Please help!
Solved by Dennis_Jeffrey. Go to Solution.
I'm not in inventor at the moment, but you will need to edit the family tables in a custom read/write content center.
In Family tables, go to Size dDesignation >> The select that column and Edit the Column Properties.
