Inventor General Discussion
517 Kudos
Post 1 of 4
Place dimension weirdness
186 Views, 3 Replies
09-05-2012 11:01 AM
Watch this video to see the issue. When I try to place an angular dimension, the view justs and the dim is not placed correctly.  This is the base view, but notice how when I try to move the view, there is a horizontal line going off into space to the right.  This should be going back toward the projected view, but its not.  If I copy/paste the view, it copies over the same behavior.
I can blow away the view and place it again on the sheet and everything works fine.
1,284 Kudos
Post 2 of 4
Re: Place dimension weirdness
09-05-2012 11:28 AM in reply to: karthur1
Wow, that is a bizzare one.
Have you tried importing the dimensions from your model?
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
403 Kudos
Post 3 of 4
09-05-2012 08:28 PM in reply to: Cadmanto
How about making sure your part face (plane) is parallel with the IDW (sheet) plane? I've had similar weird results with complicated FG members that I have demoted to an assy file so I can detail them. Because the FG member uses the Frame UCS. From memory you can select the first dimension line and then RMB and there is an option for selecting the alignment? of the dimension with the part or the sheet plane. I forget the exact terminology as I don't do it too often.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2014 PDS Premium SP2 Update 2, Vault Professional 2014 Subs Release 1 & Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
517 Kudos
Post 4 of 4
09-06-2012 06:13 AM in reply to: brendan.henderson
brendan.henderson wrote:
.... From memory you can select the first dimension line and then RMB and there is an option for selecting the alignment? of the dimension with the part or the sheet plane.....
I dont have a right-click option like that when I am dimensioning.  I did make sure that the part face was parallel with the sheet (Edit View>Change view orientation).  It still jumps when I place the angular dim.  It is easy enough to fix for this one part (delete view and redimenion).  Good thing it is just this one view.
This idw was a "Copy Design" of another design. The original idw was created in 2010 and it does the same thing, so it is not a 2013 thing.  I could send the file to AD if someone there is interested in looking at it and try to see why the view is hosed (ref. F3253-066)
