Inventor General Discussion
Active Contributor
conbuc
Message 1 of 5 (406 Views)
Place a hole referenced from a plane instead of an edge.
406 Views, 4 Replies
10-19-2012 11:26 AM
I would like to use the hole command to place a hole in a part. When I place the hole it won't allow me to use one of the origin planes to locate the hole from. Can I only locate holes off edges?
Hi conbuc,
If you create a sketch on the plane and insert a sketch point, you can then create the hole from the sketch point using the hole tool.
I hope this helps.
Curtis
Curtis_Waguespack
Message 2 of 5 (403 Views)
Re: Place a hole referenced from a plane instead of an edge.
10-19-2012 11:34 AM in reply to: conbuc
Hi conbuc,
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
mrattray
Message 3 of 5 (392 Views)
10-19-2012 12:12 PM in reply to: Curtis_Waguespack
This is the only workflow I use for holes. I never liked using the hole command's dialog for defining the hole position in Inventor or SolidWorks.
Mike (not Matt) Rattray
*Pro
sbixler
Message 4 of 5 (356 Views)
10-20-2012 11:07 AM in reply to: mrattray
I agree, with a couple of exceptions-- creating a sketch for a hole concentric to another circular feature is way more work and no improvement over using the Concentric placement option.  And once in a while, the Point option also saves a lot of work.
Active Contributor
conbuc
Message 5 of 5 (306 Views)
10-22-2012 07:19 AM in reply to: sbixler
Thank you all for the responses. I will use sketches to place or locate my holes.
It does suprise me however that Inventor would not allow the hole to be referenced off of edges AND/OR planes. Inventor already knows where the planes are and in many cases I want the holes to stay put based on the center of the part, not off one edge.
