I reciently moved from SolidWorks to Inventor and I'm currently creating an assembly and I was wondering if it is possible to drag and drop opend files into an assembly like in SolidWorks or you need to go and selected from its location using the Place menu?
Is there a way to place a component that is currently opend into an assembly?
Thanks a lot.
Solved by Curtis_Waguespack. Go to Solution.
Hi fsdolphin,
Also, if you make the assembly window and the part window visible at the same time (View tab > Tile button), you can click on the top level node in the model browser and drag the part into the assembly.
You can also drag and drop from a Windows Explorer folder into an assembly.
I hope this helps.
Curtis
All three methods you suggested worked fine. Thanks a lot for your help.
