Inventor Forum
Pipe Tap
2 REPLIES 2
DMF
171 Views, 2 Replies
Pipe Tap
Is there a way place pipe tap holes NPT.
2 REPLIES 2
in reply to: DMF
Extrude a circle. Then apply the thread command. NPT will be one of the
choices. If you draft the hole the NPT will be the default choice.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"DMF" wrote in message
news:f152e37.-1@WebX.maYIadrTaRb...
in reply to: DMF
I usually use a countersunk hole, that way you get the tap drill and tapered
thread surface. Then apply the thread to the taper.
