When Routing a Pipe and Tube in my model an error that says "...pipe and tube style not available..." (See Screenshot 1).
Software version in 2013 (Autodesk Inventor)
Operating System: W7 64 bit.
Every single default styles had returned the same error. It seemed everything in my content center has been deleted. Even ‘Place from Content Center’ has no parts in it anymore and I noticed this at the same time I can’t create the pipes. See screenshot 2 and 3 for reference.
I've seen several related posts and it is not clear if this is a bug or missconfiguration? Please advise.
Solved by cbenner. Go to Solution.
Solved by salariua. Go to Solution.
You need to go into Inventor / Manage / Project / Configure Content Center Library / and make sure the libraries are available and ticked on.
For tube and pipe you need "Inventor Routed Systems".
Also need to fisrt make sure you are working in the correct project. Sometimes Inventor will change to the default project without you knowing it, and your libraries and search paths may not be properly set. So, first make sure you are working in the correct project file... then check the library settins as Adrian suggested.
Let us know how it goes and good luck!
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
All of my Things are checked on and it still doesn't work. Thanks for trying though.
