Inventor Forum
Pick and place movements - cool robot clip
1 REPLY 1
xchrisgrassx
422 Views, 1 Reply
Hello all,
If you're interested take a look at the attached video clip.
What you will see is one robot tending two tool changers.
I know the quality was rushed, but you should see that one of the two stands actually has the end effector tooling on it.
My question is how do i define a grip from the robot to that tool, so I can move it to the other riser (as you can tell from the animation).
I am not working in Inventor Studio, otherwise this would be somewhat simple. I am doing this in Dynamic Simulation.
My thought was to create a spacial joint between the robot and the tool. But then how would I control through the timing where its location is?
Thanks in advance.
1 REPLY 1
xchrisgrassx
in reply to: xchrisgrassx
Is the solution to just splice multiple renders together?
For example, do the first 3.5 animation without tooling.
Then animate another with tooling.
Then a last animation dropping the tooling. I would then go try and add them to form one?
I don't like the thought of that, but I don't see any other option..
