Hello all,
If you're interested take a look at the attached video clip.
What you will see is one robot tending two tool changers.
I know the quality was rushed, but you should see that one of the two stands actually has the end effector tooling on it.
My question is how do i define a grip from the robot to that tool, so I can move it to the other riser (as you can tell from the animation).
I am not working in Inventor Studio, otherwise this would be somewhat simple. I am doing this in Dynamic Simulation.
My thought was to create a spacial joint between the robot and the tool. But then how would I control through the timing where its location is?
Thanks in advance.
Is the solution to just splice multiple renders together?
For example, do the first 3.5 animation without tooling.
Then animate another with tooling.
Then a last animation dropping the tooling. I would then go try and add them to form one?
I don't like the thought of that, but I don't see any other option..
