Inventor Forum
Physical vs Virtual memory
2 REPLIES 2
mpatchus
396 Views, 2 Replies
Can anyone explain why Inventor is using so much (or ANY for that matter) VIRTUAL memory when I have ample physical memory available.
Why doesn't it utilize all of the available physical memory before using virtual memory?
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
2 REPLIES 2
BarryZA
in reply to: mpatchus
Maybe I'm punching above my weight here, but one time when I added more RAM and I went in here, it was still showing the old value.
4donwan4
There is not anyone from the user standpoint that could answer this because it would involve an understanding of how the code operates, it would be more from the developers and QA side to post a reason for this. Being from the support end of it this has been common amoung releases. As the software gets more complex this has gone up over the releases. I will defer to the other teams to post a response.
Don
