I have a .iam and .idw that i copied/designed from vault. The .idw has a sketched symbol that has a text box with the mass property. When update mass is applied the mass property in the text box does not. I ran into this once before and got it to work by re-inserting the symbol into the .idw but I can't get it to work. The orginal that was copied from works fine.
IV2013
Vault Collaboration 2013
Gordon
Solved by gordon.rogers. Go to Solution.
Hi gordon.rogers,
If you edit the model file and go to the Manage tab and click the Update Mass button, does that resolve this for you?
I hope this helps.
Curtis
