Inventor General Discussion
Active Member
bodich
Message 1 of 5 (709 Views)
Physical Inventor properties
709 Views, 4 Replies
09-16-2012 09:34 AM
In properties on physical tab Plumbum has density 0.940 g/cm3, but it should be 11.34 g/cm3. But in material editor it has right value. What should I do? Maybe it is config file somewhere?
Thank you for answers. After checking Lead in properties, I closed properties window. After reopening properties it is all right. And every time like this: Lead value is wrong, but after accepting and reopening Properties, value became correct.
*Pro
sbixler
Message 2 of 5 (638 Views)
Re: Physical Inventor properties
09-17-2012 05:13 AM in reply to: bodich
In English, I think the material you're referring to is "Lead".
As far as the density: it appears that you are using Inventor 2013; when I create a part in 2013 made of lead, the density in iProperties matches the Material properties.  Is it possible that the density has been manually edited in the file?
JDMather
Message 3 of 5 (635 Views)
09-17-2012 05:17 AM in reply to: bodich
Attach the file here or create a cube 1cm x 1cm x 1cm and attach it here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Valued Contributor
HenrikGraversen
Message 4 of 5 (518 Views)
11-09-2012 01:27 AM in reply to: JDMather
I have the same problem with Aluminum.
If i create a simple new part / cube 10 x 10 x 10 cm. it has the correct weight and density.
But if i derive an assembly in to the part as a surface model the density change.
Kind regards
Henrik Graversen
Active Member
bodich
Message 5 of 5 (445 Views)
12-01-2012 07:04 AM in reply to: bodich
