Can someone please expalin how I can create a proper phillips head indent in a screw head. I looked at the model in the Content Center, but they are using all these variables which I do not understand?
Thx
Kev
You could sketch your Phillips Head Socket Profile then extrude cut with a negative taper?
Do you really need this??
I just make a plus shaped extrusion and add some taper (maybe a chamfer here or there if I'm bored). No need to model geometry that isn't needed/overly complicated.
