I have a situatuion where I have some parts in an assembly that have been set to BOM Structure Phantom, (I didn't use Reference due tho the display issues with Reference parts in the idw. ie, portions not showing as hidden when they should) I need all parts that are set as Phantom to display in a different color in the idw. Any idea how I can assign the Phantom parts to a different layer? These are existing parts of the install and need to be displayed differently. Seems like Phantom would work best, if I could control the color of the display in the idw. I cannot do this line by line, since there will be many parts all the time!
Solved by mcgyvr. Go to Solution.
You should be using "reference".
The only issue with reference parts is how they display in isometric views..Is that the problem you are talking about?
If not simply setting "hidden line calculation" to All Bodies instead of reference data separately will fix your problem and allow you to use reference as you should be.
If you must use phantom the best thing would be to put all those parts into their own assembly ..then you can select the sub at one time and change it to a different layer. Otherwise you will be selecting parts 1 by 1 (no need to go line by line).
