Inventor Forum
Peventing Assemby Rotation
1 REPLY 1
267 Views, 1 Reply
I want to make an assemby consisting of 3 parts. A crank shaft and a crank pin that screw into threaded holes in a crank disk. How can I insert them and prevent them rotating in their holes but still allow the whole assembly to rotate around the axis of the shaft? Also how could I lock a flywheel on to the shaft so that whole assembly can rotate togeather?
1 REPLY 1
JDMather
Apply assembly constraints.
Mate workplanes is often a solution.
Use logical sub-assemblies.
Attach your assembly here.
