Inventor Forum
Periodically Deleting Old Vers Folders?
11 REPLIES 11
Message 1 of 12
136 Views, 11 Replies
Periodically Deleting Old Vers Folders, is there a problem with doing this?
I just do a search for any folders named old version and then delete them
all.
I have only done this once and it did not seem to cause any problems and I
figure I will do it once a week or so just to keep the size down.
11 REPLIES 11
Message 2 of 12
All it will do is lose your old versions - if you don't need them, no
problem.
"Albert Allen" wrote in message
news:D8EFCD6224EDC3E025245CDC5138AA9B@in.WebX.maYIadrTaRb...
this?
> all.
Message 3 of 12
As long as you're sure you won't have to back up (from your drafting
table) to recover work. I delete mine about once a week. You know that
you can set them for many versions?
darvin
this?
them
> all.
and I
Message 4 of 12
Albert
Silly me... I have to ask WHY? You probably have the strongest machine I
have seen specs of posted here, so I can't imagine a company that would buy
something like that is shy on space.... so what is the purpose of deleting
them? Boredom setting in because you are getting so much done with R7
compared to R5.3 8^))
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
Assistant Moderator
Autodesk Discussion Forum Moderator Program
this?
> all.
Message 5 of 12
I never thought about deleting these files either Kent - with my Dual 120GB
drives and such - but then when I read his message I went and deleted all
the "oldversions" folders on my M50 notebook I was working on at the time -
1GB of data taking up my 30GB HD.
When I got home, I did the same on my main workstation - 2GB of data! WOW!
"Kent Keller" wrote in message
news:58981EE79100E68599BFF200FEA626F6@in.WebX.maYIadrTaRb...
| Albert
buy
Message 6 of 12
Deleting is easier, but why not use Purge or Purge All to clean them out?
Inventor is just going to create the OldVersions folder anyway.
Mike
this?
> all.
Message 7 of 12
What is "purge"? Is this a windows or Inventor thing?
"Mike Maenpaa" wrote in
message news:D6797E14D4C880EFFCB1BFC1089AE811@in.WebX.maYIadrTaRb...
| Mike
Message 8 of 12
It cleans out the OldVersions folder when RMB a specific file. If you RMB a
folder, it cleans out everything.
Mike
"Ron Crain" wrote in message
news:8CBD825C48C98B944089F16B338E1220@in.WebX.maYIadrTaRb...
out?
> | Mike
Message 9 of 12
P.S.
It's an Inventor thing.
Mike
message news:1AC0C466A288D3EE65109DF6EED63085@in.WebX.maYIadrTaRb...
a
> Mike
Message 10 of 12
I will still take giving up the unneeded space to have a recovery method when needed. If
it gets to a point where we are tight on diskspace I will consider doing something. If
anything I would probably make a batch file that only deletes them after they are a month
old or something like that.
Kent
Assistant Moderator
When posting Attachments Please Zip first and Use the new IVCF
Web http://discussion.autodesk.com/WebX?14@186.Fx3taaT3ofu.79@.f15ad3a
Newsreader news://discussion.autodesk.com/autodesk.inventor.customer-files
news:BF3DC8C11AA7D17C43412A82F3BEDC0B@in.WebX.maYIadrTaRb...
Message 11 of 12
I agree- but I had my old versions set to 8 for current projects and there
were a LOT of old projects that are closed and over with that I never
purged.
I was just surprised at the amount of space I was taking up on the small
30GB drive on the notebook.
news:895510BF7866550DEB5C13838B028D1F@in.WebX.maYIadrTaRb...
when needed. If
something. If
they are a month
Message 12 of 12
Hey Kent, I take my work home with me on an external HD and it is
synchronized to the main HD that all of our CAD data is on and any extra
files makes the sync. take longer.
The bottom line is I have a real personal issue with the stupid "old
versions folder"..after all R7 works so well I need something to complain
about
> Albert
buy
> Kent Keller
> Assistant Moderator
> this?
them
> > all.
I
