we are running autodesk vault (basic) on a local (in the building) server. ICT wants to move this server to a other location (other city). I can imagine that this will not improve the performance. I want to measure the performance/speed while the server is still in the building and when it has been moved.
I tryed to write a tool in c# that would open a file, check it out and in ahther that it should calculte the time it took. But i didnt manage to finde a way to do this with the vault basic
Is there a tool wich wich can do this or wich can do some other performance/speed check between inventor and the vault?
(it might also be because i'm not a great programmer that i didnt manage. if some one has some source code for: Making a connection to the vault basic, openingen a hard coded file and checking it out and in. then i will manage to make the program my self ;-).
Maybe have a look at ProcMon, and use it to monitor the system while doing some typical tasks. If you can narrow down the processes to only those you are interested in it should give you an idea.
ProcMon was to complicated for me. I end with the "task scheduler". i made 2 tasks. 1 for checking out a folder and a other to check it in again. (i use a folder from more or less 1300 files.) then i look at the log files because i can find there the start time and end time of the process. if i supstract those times i know what time it takes. its a very basic test but the best i could come up with.
