Inventor Forum
PDF Printing Problem
7 REPLIES 7
Message 1 of 8
selby
1322 Views, 7 Replies
Using Photoshop CS3 and Adobe PDF CS3 I have the Adobe printing problem illustrated by the three shots in this attachment. The coloured elements in the 'drawing' image become horizontal stripes in the pdf 'print'. The same problem happens in the same way if I attempt a monochrome print.
And of course this new 'feature' happens just as a client is urgently awaiting a set of drawings for production approval!
Can anyone suggest the cure please?
Ralph Selby
7 REPLIES 7
Message 2 of 8
in reply to: selby
Change the PDF setting for your Adobe "printer" from "Standard" to "High
Quality".
Dell 670 dual Xeon - 3.2
3gb memory, SCSI320-15k
XP-Pro, sp2
Quadro FX3400: Driver: 162.65 Direct3D
IV2008-pro sp2,
SpacePilot Rel V: 3.5.4 Dvr V: 6.4.4 Firmware 3.12
wrote in message news:5827995@discussion.autodesk.com...
Ralph Selby
Message 3 of 8
selby
in reply to: selby
Many thanks Blair - I'd just upgraded to CS3, seems the PDF module installs at its lowest setting!
Ralph
Message 4 of 8
in reply to: selby
This was an issue with CS2 as well on larger drawings.
Dell Precision 690
Dual Quad Core E5320 @ 1.86GHz
4Gb DDR SDRam - 667 Mhz, ECC
SAS 146Gb - 15k rpm
Quadro FX3500 256Mb - Driver: 162.65 Bios: 5.71.22.55.08
XP Pro Sp2 - AIP 2008sp2 - D3D
Space Explorer USB 3.5.6
wrote in message news:5828687@discussion.autodesk.com...
Ralph
Message 5 of 8
alh-telesis
Wow, 2010 and this is still and issue.
Thanks Blair.
Windows 7, 64 bit
Adobe Acrobat 9 Standard.
IV 2009 (Yes I know it's supported on Windows 7)
PDF printer was making those fun stripes.
Uping the printer's quality to High solved the issue.
Message 6 of 8
msklein
in reply to: alh-telesis
My question is how do you get the settings to stay so you don't have to remember to make these settings every time you need to do a PDF.
MSK
Message 7 of 8
alh-telesis
Man I need to work on my proof reading skills.
What I meant to say was ...
"is still an issue"
and
"(Yes I know it's NOT supported on Windows 7)"
As far as making the setting stick, I think I know what you're talking about.
If you make a change to the printer setting from inside a program, the changes are temporary.
Example If you are in Excel and select print and then go to printer properties, all of those changes are associated with that one spread sheet.
What you need to do is go to the "Start" button and then click on printers. When you right click on the Adobe Printer and go to Preferences, any changes you make now will stay with the printer.
Hope that helps.
Message 8 of 8
blair
in reply to: selby
In Win7, you can: Start>Devices and Printer>Adobe PDF>RMB>Printing Preferences>High Quality.
Delta Tau Chi ΔΤΧ
