When I Export to PDF and click on "Options" I am unable to select "Print all sheets"
Any suggestions?
Are you seeing this? You can only "Print" multi sheets within in the Inventor IDW file. You can't have multiply IDW files opend and try and print them within Inventor. If you are trying to "Print" multi-Inventor files, you might check the Add-in (upper RH blue X in the main menu) "Print Manager" or "Drawing Porter".
