Inventor General Discussion
Distinguished Contributor
SveinE
Message 1 of 5 (1,313 Views)
PDF Line weight
1313 Views, 4 Replies
06-30-2010 05:29 AM
Hi
When printing to PDF from IV the Line weight is to thick even when removing "Object Line weight"
How to control this ?
br
Svein
Valued Mentor
delineryan
Message 2 of 5 (1,312 Views)
Re: PDF Line weight
06-30-2010 05:38 AM in reply to: SveinE
Its in the options section when you save the PDF, see picture.
Ryan
Ryan
Inventor Version:
Build: 535, Release: 2011 SSR - Date: Fri 08/20/2010
64-Bit Edition - 8192.00 GB
Dell Precision T3500
Intel(R) Xeon(R) CPU W3540 @ 2.93GHz (8 CPUs), ~2.9GHz
6.00 GB RAM
Windows Vista™ Ultimate (6.0, Build 6002) Service Pack 2
NVIDIA Quadro FX 1800 8.17.0012.5849
SveinE
Message 3 of 5 (1,305 Views)
Re: PDF Line weight
06-30-2010 05:45 AM in reply to: delineryan
Hi
Thanks for quick reply, but this is what I have done.
I wan't it thinner? Is there an setting to control that?
If you save the IDW as DWG an then print to PDF the lines are thinner, so I think it is an Inventor setting
br
Svien
Valued Mentor
delineryan
Message 4 of 5 (1,303 Views)
Re: PDF Line weight
06-30-2010 05:48 AM in reply to: SveinE
I am not too sure, I only use dwg's, maybe someone else has some expertise in this area.  That check box is what I use to control line weights on pdfs.
Ryan
Inventor Version:
6.00 GB RAM
**Master
BMiller63
Message 5 of 5 (1,290 Views)
Re: PDF Line weight
06-30-2010 06:19 AM in reply to: SveinE
edit the layers used and set the lineweights there (or set them to zero maybe)
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
