Inventor Forum
PDF Line weight
4 REPLIES 4
SveinE
2178 Views, 4 Replies
PDF Line weight
Hi
When printing to PDF from IV the Line weight is to thick even when removing "Object Line weight"
How to control this ?
br
Svein
4 REPLIES 4
delineryan
in reply to: SveinE
Its in the options section when you save the PDF, see picture.
Ryan
SveinE
in reply to: delineryan
Hi
Thanks for quick reply, but this is what I have done.
I wan't it thinner? Is there an setting to control that?
If you save the IDW as DWG an then print to PDF the lines are thinner, so I think it is an Inventor setting
br
Svien
delineryan
in reply to: SveinE
I am not too sure, I only use dwg's, maybe someone else has some expertise in this area.  That check box is what I use to control line weights on pdfs.
BMiller63
in reply to: SveinE
edit the layers used and set the lineweights there (or set them to zero maybe)
