Hi
When printing to PDF from IV the Line weight is to thick even when removing "Object Line weight"
How to control this ?
br
Svein
Its in the options section when you save the PDF, see picture.
Ryan
Hi
Thanks for quick reply, but this is what I have done.
I wan't it thinner? Is there an setting to control that?
If you save the IDW as DWG an then print to PDF the lines are thinner, so I think it is an Inventor setting
br
Svien
I am not too sure, I only use dwg's, maybe someone else has some expertise in this area. That check box is what I use to control line weights on pdfs.
