I found this code and have been using it for quite some time to create pdf's from assemblies written by Curtis Waguespack.
I've searched but I cant figure out how to modify it to make views precise.
Is there any way to make the code process the Make All Views Precise before it begins to process the pdf file?
I've tried adding a line to pause the code after open to give the file time to process the InventorViewCompute.exe but it is only doing the active sheet and the others arent processing, and therefore are raster.
I've attached a pdf, notice the 2nd page is precise due to it being the active sheet when the idw file opened, and the 1st page is in Raster view.
Note that when these files were closed, they were all saved in Precise view.
'define the active document as an assembly file Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisApplication.ActiveDocument oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4) 'check that the active document is an assembly file If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then MessageBox.Show("Please run this rule from the assembly file.", "iLogic") Exit Sub End If 'get user input RUsure = MessageBox.Show ( _ "This will create a PDF file for all of the asembly components that have drawings files." _ & vblf & "This rule expects that the drawing file shares the same name and location as the component." _ & vblf & " " _ & vblf & "Are you sure you want to create PDF Drawings for all of the assembly components?" _ & vblf & "This could take a while.", "iLogic - Batch Output PDFs ",MessageBoxButtons.YesNo) If RUsure = vbNo Then Return Else End If '- - - - - - - - - - - - -PDF setup - - - - - - - - - - - - oPath = ThisDoc.Path PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium If PDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then 'oOptions.Value("All_Color_AS_Black") = 0 oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets 'oOptions.Value("Custom_Begin_Sheet") = 2 'oOptions.Value("Custom_End_Sheet") = 4 End If 'get PDF target folder path oFolder = oPath & "\" & oAsmName & " PDF Files" 'Check for the PDF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If '- - - - - - - - - - - - - '- - - - - - - - - - - - -Component Drawings - - - - - - - - - - - - 'look at the files referenced by the assembly Dim oRefDocs As DocumentsEnumerator oRefDocs = oAsmDoc.AllReferencedDocuments Dim oRefDoc As Document 'work the the drawing files for the referenced models 'this expects that the model has a drawing of the same path and name For Each oRefDoc In oRefDocs idwPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "idw" 'check to see that the model has a drawing of the same path and name If(System.IO.File.Exists(idwPathName)) Then Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.Documents.Open(idwPathName, True) oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName) -3) On error Resume Next ' if PDF exists and is open or read only, resume next 'Set the PDF target file name oDataMedium.FileName = oFolder & "\" & oFileName & "pdf" 'Write out the PDF Call PDFAddIn.SaveCopyAs(oDrawDoc, oContext, oOptions, oDataMedium) 'close the file oDrawDoc.Close Else 'If the model has no drawing of the same path and name - do nothing End If Next '- - - - - - - - - - - - - '- - - - - - - - - - - - -Top Level Drawing - - - - - - - - - - - - oAsmDrawing = ThisDoc.ChangeExtension(".idw") oAsmDrawingDoc = ThisApplication.Documents.Open(oAsmDrawing, True) oAsmDrawingName = Left(oAsmDrawingDoc.DisplayName, Len(oAsmDrawingDoc.DisplayName) -3) 'write out the PDF for the Top Level Assembly Drawing file On error Resume Next ' if PDF exists and is open or read only, resume next 'Set the PDF target file name oDataMedium.FileName = oFolder & "\" & oAsmDrawingName & "pdf" 'Write out the PDF Call PDFAddIn.SaveCopyAs(oAsmDrawingDoc, oContext, oOptions, oDataMedium) 'Close the top level drawing oAsmDrawingDoc.Close '- - - - - - - - - - - - - MessageBox.Show("New Files Created in: " & vblf & oFolder, "iLogic") 'open the folder where the new ffiles are saved Shell("explorer.exe " & oFolder,vbNormalFocus)
Hi, have you found an answer to this? Today I am using the same code and some of my exported pdfs are in low-quality raster view. Thank you
@Anonymous
This posting is about 3 years old and the OP hasn't visited the forums in over a year.. Paging Dr @Curtis_Waguespack
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hi everyone,
This is what I had on hand concerning precise views.
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
'Iterate through all sheets For Each oSheet In ThisDoc.Document.Sheets 'Iterate through all views on sheet For Each oView In oSheet.DrawingViews 'set view to be precise oView.IsRasterView = False Next Next
