taking too much time for pdf creating, so software got automatic updates, please help reg this,
when i create pdf its shows following window, but taking too much time to create
What method did you use to create the pdf file? Can you post your system specs? Looks like you have a lot of windows open, are you pushing the limits of your resources?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
step for pdf creation for a IDW file
Inventor>save as> save copy as
and thn am choosing option PDF, all pages (in options)
system specs>
windows xp x64
8 gb ram
core i3 3.9 GHZ
Try using the plot command, there should be a PDF option. This MAY be a little quicker, I've never compared the two methods side by side.
Chris Benner
but that plot is for printing
and second if i print pdf (using external software) using plot thn it comes in image form, where am not allowed to copy text
resoloution is not so much good as i saw in save pdf option.
and there is no option in plot, where i can print pdf
Well, if you need the ability to edit, then that won't work for you. I assumed you needed only a pdf for imaging.
Chris Benner
i just need pdf for view to my customer, not for editing
and that pdf printing using plotter, doesnt provide layer
which i can turnoff layers in PDF
sometime i need pdf for copying data (text)
so can u provide any other method, or any soloution how to overcome to this problem
system spec's?
Should be able to use the File>Export>Pdf
Runs fast here
just use Bullzip, plus save in png, tiff, bmp etc. Works with any program.
