Hi! Is it possible to patter direct edit feature. i have a feature on the part that i modified with direct edit, but now cant select that direct edit feature to pattern it together with the part. am i doing something wrong or is just no possible.
Best Regards.
Solved by mflayler2. Go to Solution.
Solved by JDMather. Go to Solution.
@eluoci wrote:
... pattern it together with the part. am i doing something wrong or is just no possible.
Sounds like you might want to select the Pattern a Solid option to pattern the entire body.
Can you attach the file here?
Hello! I have the following problem:
I want to pattern A FEATURE with direct edit applyed to it, but when I try to do it
Inventor says direct edit can't be patterned so I can only pattern the feature without the edit...
To make it clear - I am making a crown and I wanna clone the gems on it, which have some rotation (screenshot in attachments).
Pls help with de issue!
Create the Loft as a new solid then direct edit it, then Pattern the solid. When finished use the Combine command to return it to a single solid part.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Thanks! That worked just as I needed! I'm afraid I can't mark this as solution cuz I am not the creator of the topic!
But thank you very much anyway!!!
