Inventor General Discussion
Active Member
bogdan.noreq
Message 1 of 7 (375 Views)
Pattern visibility
375 Views, 6 Replies
06-28-2012 11:26 PM
Hi!
Can anybody explain to me why if in .iam view representation I make "component patterns" invisible, thay still on .idw drawing are visible, and worse part is that I can not turn off visibility manually in browser. Please see attach.
Thank you for your time :smileyhappy:
Autodesk Inventor Professional 2013
Windows 7 64-bit
Distinguished Mentor
IgorMir
Message 2 of 7 (347 Views)
Re: Pattern visibility
06-29-2012 05:16 AM in reply to: bogdan.noreq
If I remember correctly - it is not enough just to turn the visibility of the pattern off. You have to expand the Pattern node and turn the visibility of the members off as well.
Igor.
Web: www.meqc.com.au
IgorMir
Message 3 of 7 (341 Views)
06-29-2012 05:27 AM in reply to: bogdan.noreq
Better yet - make sure the drawing view is associative to the assembly. Here is a snap shot of what to look for.
Igor.
andrewiv
Message 4 of 7 (322 Views)
06-29-2012 05:53 AM in reply to: bogdan.noreq
I've had this same issue with IV 2012 SP2.  They release a hotfix to correct the issue for 2012, but not sure about 2013.
Inventor Professional 2014 SP2
Vault Professional 2014 SP1
Windows 7 64 bit
Active Member
bogdan.noreq
Message 5 of 7 (320 Views)
06-29-2012 05:55 AM in reply to: IgorMir
Hi!
Thanks for answer. Yes - it is checked. I think it is by default always checked.
I do not want to expand pattern - it make assemblys list full of not useful information :smileysad:
Спасибо за ответ! :smileyhappy:
Windows 7 64-bit
IgorMir
Message 6 of 7 (294 Views)
06-29-2012 06:50 PM in reply to: bogdan.noreq
Then it is probably a bug in the latest release of IV. In IV2010 it works - as expected.
Best Regards,
Igor.
P.S. Привет, Богдан! Рад помочь, если могу. Где Вы живёте? Для переписки на русском - можно использовать мой адрес со страницы. До связи!
Product Support
innovatenate
Message 7 of 7 (245 Views)
07-17-2012 05:06 PM in reply to: bogdan.noreq
I am not able to reproduce this using simple assembly that I have created to test this. I've uploaded my test files to this post. I'm think you may be in a Master View Representation or perhaps the View Representation is Locked
Please see the attachments for clarification.
Nathan Chandler
