Dan,
One caution on this approach. I've run across a number of parts where the
centered pattern is created as a single "rectangular" pattern with the 2nd
direction opposite to the first, resulting in a lot of overlapping
occurrences. Let's say you want a row of 19 Holes spaced 1" - the original
is modeled in the center position. If you create a rectangular pattern with
direction2 opposite to direction1, count1 = 10, spacing1 = 1", count2 = 10,
spacing2 = 1" the result will *look* correct, but Inventor has generated
100 holes most of them overlapping. To visualize this, set direction2 to be
not quite opposite direction1 (try 175 deg) - now you can see all 100
occurrences. They will still be there when direction2 is 180deg to
direction1. (You can also see them in the browser if you expand the Pattern
entry.) These extra pattern occurrences obviously degrade the performance
in the part.
One solution is to set count2 = 2, spacing2 = (count1 - 1) * spacing1. This
still leaves one occurrence overlapping on top of the original. Another
solution is to create two patterns.
Tom Sturtevant
Inventor Part Modeling
"dan_mayers" wrote in message
news:f18d725.12@WebX.maYIadrTaRb...
Having read all of the responses to your original question, I think that
there is only one way to get what you are after. The problem is that the
pattern is fixed on the first instance- you can't keep the 1.5" spacing and
have the two end features have the same distance to the end of the part,
correct?
The only way I found around this was to work from the center of the part.
Dimension your first hole as 1/2 the total distance of your pattern, and
then create the pattern. That way your equally spaced pattern will always be
centered on the part. Not very graceful, but I think it will do what you are
asking.
