Inventor General Discussion
Distinguished Contributor
jostroopers
Message 1 of 3 (141 Views)
Pattern in new folder
141 Views, 2 Replies
02-04-2013 12:36 PM
If I place many parts  than i create a new folder in the browser and place all parts in the new folder.
If I make a pattern of the same part that pattern I can not drag to the new folder where all the other equal parts are.
Well, I can right click on the pattern and then add to new folder but I can not click on existing folders so get a new folder is created where the pattern is placed.
Is it not possible to have a pattern to an existing folder to drag?
Mvg Jos
Youre drawings are as good as the symbols that compleet them.....
You should be able to drag the pattern into the folder, but I believe it has to be under the LAST item in the folder.
Expand the folder and try dragging the pattern under the last item (you should see a LINE appear below the last item as you drag the pattern into position).
Valued Mentor
mpatchus
Message 2 of 3 (112 Views)
Re: Pattern in new folder
02-05-2013 04:26 AM in reply to: jostroopers
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
jostroopers
Message 3 of 3 (86 Views)
02-06-2013 01:20 PM in reply to: jostroopers
Thanks, you must exactly click the right place.
It must be done exactly.
Some times i go over the new folder and it turns blue and then it works to.
Thanks again.
Mvg Jos
