Inventor Forum
Pattern iMates
4 REPLIES 4
ymustiregister
722 Views, 4 Replies
Pattern iMates
I have a part which has multiple connection points for an item.
As the part can be created by patterning using a linear array, I was wondering if I could pattern the imates as well?
Thanks.
4 REPLIES 4
in reply to: ymustiregister
Sorry Inventor doesn't have the capability to pattern iMates.
Gary Tafoya
Autodesk Inventor Assembly QA
wrote in message news:5948058@discussion.autodesk.com...
Thanks.
wr57034
Inventor 2014, Vault 2014, Enovia
Stratasys 3D printing
t_stramr
Patterning iMates is not supported by Inventor. If your connection points are based on some features you can use Infer iMates command for automatic iMates creation on selected features. iMates are created based on features geometry.
JEHADESIGN
Hi
Unfortunate this feature still doesn't work with 2020.
I used an alternative when pattering inserts by using "Feature Pattern Select" with reference to the pattern holes !
Hope this will help  !
Claus
