<RyanBotha> wrote in messageHi
href="news:6316594@discussion.autodesk.com">news:6316594@discussion.autodesk.com...
all,
I'm trying to create a pattern of holes on a plate that will house
tubing. The pattern is not that straight forward though. The holes must avoid
sections for support steelwork, and the holes themselves must not escape a set
boundary constraint. To make the problem a little more complicated, the part
is parametric, so if the diameter of the plate changes, or the boundary
changes, the hole pattern must increase to fill the extra space, without
cutting through the boundaries. To illustrate my part, i have attached a part
that was drawn in PRO-E.
The steps are simple in PRO-E; Create the
sketches, specify the boundary of the pattern, and fill that boundary with the
holes. I have tried using the 'Grill' feature, as that allows boundaries, but
not success.
Any ideas? I would like to prove that Inventor can do
this, as decisions have just been made to use Inventor over Pro-E, which I
fully support.
Kind Regards,
Ryan
<RyanBotha> wrote in messageSo
href="news:6318007@discussion.autodesk.com">news:6318007@discussion.autodesk.com...
I've found a neat little way to create a pattern within a constrained area,
using the multi-solid feature. Just create the entire solid, and then split
the solid with a sketch. Then create the normal rectangular pattern, but
choose the inner solid shape as the affected solid.
You will still have to
go afterwards and suppress the holes to lie over the boundary, but thats still
better than editing the extrusion of a sketch, or not making it at
all.
