pattern feature should line up correctly at 89.88deg (mirror features lines up at 89.88deg correctly - not used in model but just for this example have included) but picture shows it overshoots slightly.Have i missed something here?
Solved by JDMather. Go to Solution.
If you dig a little deeper I think you will find that the 49.44 deg. angle from the vertical centerline to the outside edge of extrusion is actually 49.43900631.
In your Circular Pattern1 dialog box enter 98.87812620444039-9 as the angle.
Or better yet - let Inventor solve the math
Add a reference dimension to Sketch1 (even though Inventor is only showing 2 decimal places in this image - it it keeping track out as many decimal places as it uses internally)
Now simply select the reference dimension in the Circular Pattern dialog box.
In this image I typed in the 9°, but I should have picked the original parameter dimension for that as well.
Any changes should update.
Well, it bothered me too much - I had to go back and fix it properly -
The CADWhisperer YouTube Channel
