I am experiencing very slow functioning of the pattern command using Inventor 2013 SP1. My design involves creating a large hexagonal mesh that I am using the pattern command to create, having set the number of items and pattern distance the command freezes for about 30 minutes presumably while it computes the command then I have to close the program and start again due to it not responding. Has anyone else finding the pattern command slows / freezes when using a large number of items ? Thanks
Inventor 2013 SP1 64-bit OS
Intel Xeon CPU W3550 @ 3.07GHz
HPZ400
12GB RAM
How many items? Can you post the file for others to try (roll the EOP marker to the top and save, then attach)? That will help to determine whether it is your system, the file, or the software.
I have found that it works better to create one cut extrusion in a feature and then pattern the whole feature, rather than to try and pattern the cut.
Try it out and liet me know if that helps.
Paul
Hi, my pattern has approximately 40 square shapes in one direction and about 25 in the other, not really a huge amount of items, unfortunately I cannot post any files due to company policy, I would greatly appreciate any tips on how to speed this process up, thanks again
1000 instances is a lot of surfaces, even if it is just a square shape. Nevertheless, 30 minutes on the PC you described seems excessive. Any way for you to try it without SP1? Either uninstall the SP or try it on another computer that doesn't have the SP installed.
Hi, thanks I will try it when I have removed SP1 and hopefully this should speed thing up.
I usually get about 5 minutes for 30-40 "items".
If you can't use a texture to just have it look like there are a lot of holes an assembly pattern seems to be faster sometimes. Make a small part of the mesh, like one cell, and make an assembly and pattern it there.
But the best way is a texture, if it's something odd you could make a small portion - pattern just enough of it so that it doesn't take to long - and take a screen shot. I have been avoiding the new appearances so if you're on 2013, someone else will have to help you figure it out.
Based on the workflow you provided, I try the general case like rectangular pattern with extrusion cut included in R2013 SP1, and it does not take so much time you talked. Maybe it is related to the case you worked. If possible, please attach the dataset or send it to me @ river-yijiang.cai@autodesk.com for further investigation.
