I have a problem with Inventor 2013. When I use Pattern to repeat a simple Sketch in 2D sketch mode, I cannot use that pattern from sketch mode to build any features, such as revolve, extrude, etc.
Please help.
Also, I can't find a link to post this request on an actual help forum. Sorry if this is the wrong medium. The help site did not have an obvious link for asking questions.
Aside from this being posted in the wrong location, are you able to pattern the original sketch as features as opposed to being in sketch mode?
Can you post a screen shot of what you are trying to do? I don't see this issue in 2015.
Jim O'Flaherty
Hi savdbygrace316,
I would encourage you to create the pattern as a feature rather than patterning in the sketch. So basically you would sketch the shape, then create a feature from it, then pattern that feature.
Rectangular feature pattern:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-C1A1FF2B-082E-4D50-911E-10343611F276
Circular feature pattern:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-B9D71D5C-C3D8-4089-A326-9DCC2B5331B1
Arrange features in rectangular pattern (there are some videos at this link)
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-07DF91E8-B342-477B-BE98-0C5A6F804A8E
Here is a related post that might be of interest:
And here is another link that might be helpful:
http://inventortrenches.blogspot.com/2011/03/inventor-101-simple-fully-constrained.html
I hope this helps.
Curtis
I first tried patterning the sketch and then extruding (which apparently doesn't work because the enpoints don't automatically connect), and it didn't work.
So, I tried extruding the basic sketch and patterning the feature. It worked, but then when I tried to do a revolve cut with the entire patterned feature, only the first block would revolve. The entire pattern would not select.
I have attached the file and some photos to show the issues.
I appreciate the advice.
A few things:
1. Constrain your sketches! Right now, Sketch 3 is pretty much unconstrained, meaning that I can click on just about anything and drag it around and then the sketch falls apart.
2. Like Curtis said - pattern features, not sketches. Patterned sketches can get pretty weird.
3. To get the revolve cut you're looking for, once you've got the extrusion patterned, create a new sketch on the face of the corrugated extrusion and project that face. Re-create your axis for the revolve feature. (When I did this I just made sketch 3 visible and projected the axis.) Use this new sketch to create your revolve cut. You've got something misaligned, though - the edges aren't clean and there's some sort of scraps laying around. I don't have the itme right now to figure out the right numbers to use.
I'd post my work on this for you to take a look at, but it wouldn't help you - I'm on 2015, and you wouldn't be able to open it.
Rusty
