Inventor Forum
Patch Color transparency problem
6 REPLIES 6
brandonherrer14
955 Views, 6 Replies
Dear Forum,
I have a problem with the patch tool. When i patch a surface, it has a orange transparency color. So, when i change the color by right clicking it and clicking proppeties to change it to the desired color (which is aluminum flat), it changes to the color but it does not look solid but instead it is see through.
How to i changed patched surfaces to a desired solid color instead of it having a transparency feel to it.
6 REPLIES 6
JDMather
in reply to: brandonherrer14
It is not solid.
If you want it to "look" solid right click on the surface in the browser and (un)select Translucent.
If you want to make it solid then Stitch or Thicken.
brandonherrer14
in reply to: JDMather
Thank You so much you always have the best answers and you are very knowledgable
cadcamm99
I unselected translucent and the color underneath still bleeds through.  If I thicken, I cannot select 0 thickness. Is there another way? I really cannot add thicknes.  It will throw off my mating part.
JDMather
in reply to: cadcamm99
Attach the ipt part here.
Is it solid in the real world?
cadcamm99
Yes, basically I am trying to show where a liquid coating is applied on a part.  The coating does not extend the whole surface of the part, only a small area. What I ended up doing was cutting out the area that was not working for me and filling the cutout with another solid body.  Then changing the color of the second body.  I can't send you the part because it is a prototype.
JDMather
It should be fairly easy to create a dummy file the exhibits all the behavior of a proprietary file.
