http://www.abcpoolleague.com/yippeepro/home.shtml
fabien.
a écrit dans le message de news:5169493@discussion.autodesk.com...
I am creating a pretty complicated iPart. Something that I would like to do
is generate the vendors part number. The part can be varying length and the
vendors part number includes this length in their number. So, when I setup
the ipart table, the "Length" field is a custom parameter that the user can
fill in. Once this is input, the vendors part number can be generated.
But since the length is a custom parameter, the part number will not be
generated correctly. I thought about using an "embedded parameters"
worksheet. I could work with this, but it will only pass values to the part
parameters and not to the iProperties.
As far as I know since R4 this has been a shortcoming. Does R11 offer
anything that will allow us to workaround this issue?
