I want to use I logic to adjust an assembly constraint based on T/F value passed from a master sketch.
I have passed the paramater T/F and/or a user paramater as described in this thread using link (neet trick).. but when the code fires it only works on the true application and not the false.. if i open the rule and then close it the update button becomes available and when updated the false condition updates sucessfully. I have tried just re-running the rule to no avail. It seams that the only way I can get it to triger a false condition is to open the rule... close it and update.
any ideas?
Hi deltades,
In the future feel free to start a new post and just add a link to this one for reference, rather than appending your new question to the existing thread. It's not a big issue either way, but you'll likely get a better response by doing it that way.
As for your question, I think we'll need to see your code, but you might try adding an Update line to your code to have it update the part.
InventorVb.DocumentUpdate()
I hope this helps.
Curtis
Edit I see you started a new post when I was typing:
http://forums.autodesk.com/t5/Autodesk-Inventor/assembly-constraints-driven-by-ilogic/td-p/3823803
If my suggestion works, please link your new thread to this one so others can find the solution in the future, otherwise just reply to your new thread.
I did.. should have started an new thread to begin with..
anyway .. see the code below
I added your suggestion but it didnt seem to help.. only if i open the editor and close it does it update.. very odd
Parameter("AC100-0100MRL-S:1", "iTrigger0101000") = 0 ul If Parameter("iTrigger0101000") = 1 Then d37_Header1 = -.25 in d34_Header2 = -.25 in ElseIf Parameter("iTrigger0101000") = 0 Then d37_Header1 = -.25 in d34_Header2 = 0.0 in End If InventorVb.DocumentUpdate()
Hi, deltades. I would guess that since the rule works when you close the editor, what's actually happening is that the rule is simply not running when the "iTrigger0101000" parameter is changed. This is simply due to how iLogic works. To make the rule run automatically, my suggestion would be to open your "AC100-0100MRL-S" part and go to the Manage tab --> iLogic panel --> Event Triggers, right-click on "Any Model Parameter Change", and add your rule to this trigger, so that it will run each time any parameter in the part file is changed.
Ok.. question.. Are you saying I can create the rule in the skeleton sketch and then push it up to the assembly?
Now that I think about it I think this can be done and it would improve the over all design.
Thanks!
