If I have a sub-assembly in my main assembly and I balloon parts of the sub-assembly, they all have the same "item no."? What am I missing here? It has been a long time since I played with Parts lists.
Solved by johnsonshiue. Go to Solution.
Kevin,
Take look at this this link to see if it helps you.
http://grabcad.com/questions/tutorial-adding-sub-assembly-parts-to-an-assembly-parts-list
There are also a lot of threads that speak to this if you do a search on this topic.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hi! It is because the PartsList references Structured BOM View (components in subassemblies are wrapped up). You need to enable Part Only BOM VIew on BOM table and create a PartsList based on the View. Then each part will have its own item number within the whole assembly.
Thanks!
