Inventor General Discussion
Cadmanto
Message 1 of 4 (200 Views)
Parts List Wrapping Direction
200 Views, 3 Replies
12-06-2012 11:39 AM
When a parts list in an Inventor drawing is wrapped it always takes the bottom portion and kicks it to the left.
Is there a way to kick it to the right?  So when you are looking at the BOM it reads such that item 1 is in the first group and not the second.
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
Hi Cadmanto,
You can right-click on the parts list and choose Edit Parts List, then click the Table Layout button, then set the wrap direction. I don't recall a way to set this up in the Parts List style, but there might be one.
I hope this helps.
Curtis
Curtis_Waguespack
Message 2 of 4 (185 Views)
Re: Parts List Wrapping Direction
12-06-2012 12:14 PM in reply to: Cadmanto
Hi Cadmanto,
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Cadmanto
Message 3 of 4 (177 Views)
12-06-2012 12:44 PM in reply to: Curtis_Waguespack
Thanks Curtis.
That was almost too easy!!!  :smileyhappy:
Best Regards,
Scott McFadden
Valued Mentor
BLHDrafting
Message 4 of 4 (155 Views)
12-06-2012 05:20 PM in reply to: Cadmanto
There is also a radio button set when placing the parts list. See graphic.
Brendan Henderson
Web www.blh.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2013 PDS Premium SP2 Update 3 (Build 200), Vault 2013 Workgroup Update 2 (Build 17.2.9.0)
