John,
Try increasing the "row gap" in your parts list style. This will increase
the clearance between the vertical line and the text. Unfortunately, it
will also increase the row height, too. You may be able to find a
compromise value.
Unfortunately, this doesn't work for revision tables.
--Nancy
wrote in message news:5867493@discussion.autodesk.com...
Thanks for the response.
No, column width doesn't provide the formatting I'm asking for. And no, I'm
not asking for it to dynamically change. I just wish to offset the text
about 1-2 spaces.
Pretend this is my part name in the box, the vertical character is the
vertical line
The parts list looks like
|ROUND BODY
What I want it to look like is
| ROUND BODY
You should be able to put space between the text and the vertical line.
Column spacing doesn't do it.
Change the column spacing, and you get
|ROUND BODY | with spaces after it (assuming it's left justified.
________
Yes, we could pad each part name by one-two space characters. This is a
nuisance downstream, for lots of other reasons.
I think this setting must exist, I just haven't found it.
- John
