If I have several "nested" sub-assemblies in my assembly, and I want to create a Parts List such that every item on the screen has a different number balloon, I know I must select "parts only" and enable the BOM view. But I still have certain items in the assembly that are still showing up as the same number when ballooning? What am I doing wrong? I must be missing a step?
Solved by Cadmanto. Go to Solution.
Kevin,
In the BOM settings in the Document settings what do you have set here?
Should be "Reference"
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
