Large Assembly / Inventor 2008
I have a layout drawing, and I want to add a parts list, but I want to break it into 2 "columns" rather then a long one
how do I do that?
Solved by johnsonshiue. Go to Solution.
Hi! Edit the parts list -> find the Table Layout button at the top in the middle -> go to the bottom of the dialog and check "Enable Automatic Wrap" option and set the desirable layout parameters.
Thanks!
JUST add another parts list then make all items not wanted shown as "visible "off as needed. I normally set off to the side a master parts list where I do all of my changes that I want to show in my parts lists. Then update others to match as required. Makes reordering much easier, along with other things. The parts list wrap just does not work the way I need it to work. I need to be able to set it's start location separately for each column when spliting or wraping.
Hi! I may not understand your requirement correctly. But, the PartsList wrapping behavior has nothing to do with which sheet it is on. The setting is per PartsList, not per Sheet. You should be able to do the same on any PartsList on any given sheet.
Thanks!
I think the idea would be to have ONE parts list and put sections of it on different sheets. For example, Split a parts list into thirds. place the first third on sheet one, the second third on sheet two and the last third on sheet 3.
My question would be: If I place different parts lists on different sheets, are they linked? For example, if I expand the list to show all components as I just did, and the parts list shows as 9, 9.1, 9.8, 9.9, 9.4, 9.5, as they just did. If I remumber 9.8 to 9.2 and 9.9 to 9.3 in the first list, will they show with the corrected numbers in the later parts lists? If not our parts lists are not really parametric, are they?
Some people have parts lists that are to big for one sheet.
They do not need different wrapping behavior depending on what sheet it is on, or whatever you were thinking might have been meant. They need to wrap the parts list from one sheet to another sheet.
Let me see if this is a little clearer:
Lets say we have an assembly with 5000 parts, each parts list row is 1/8 of an inch tall, and we have several columns so the rows are about 22 inches long. Now our plotter can only print a 22 inch wide by 400 inch long drawing. Where do we put the other 2116 rows? Huh?!? Where would you like us to put them? (I think I know what you're thinking but there are rules on forums like this so let's just move on.)
No that was a little extreme, lets assume a 34 wide x 22 high sheet and an 8 inch column. Not considering the border or the title block, we could put 4 columns of 176 rows at 1/8" tall, that gives us an absolute maximum of 704 rows per sheet. With a title block and border we'll probably loose 26 rows or so (1/2" top and bottom and 2 1/4 for the title block sound about right? - The old generic one was 2 1/2 with 1" top and bottom but 150 rows is a nice round number to work with) so that gives us a practical number of 600. And that's with no views, okay, lets put all the views on other sheets, that'll be fine I guess, but NO ONE TOLD US WE HAD TO STOP WHEN THE ASSEMBLY GOT TO 600 PARTS!!!
Sorry about that, I'm yelling now so I'm going to stop.
I understood that we will keep bagging Autodesk to split part list in to different sheets but they will never do this... I given up...
Well, Autodesk will never confirm this demand but we need to solve it. Because we're preparing spare part book for big agricultural machines. And each sheet can only have 25 rows of part list. And sometimes we may have 100 parts on one ipn file with baloons. Normally we were using filter the part lis acoording to "Item Number Range"... But we are using "structured legacy" choice. Than sometimes item numbers may be "1-2", "10-2" etc... And In this case it's impossible to use filer "Item number range". Because Filter options did not confirm from "1" to "1-8"... Again frustration!! 😞
I will try to write macro code in Invetor. I will create main part list. Let's say 100 rows. I will create extra sheet in code and copy part lists in new sheet. And there will be row quantity in code form window. Let's say 25 rows...
My code will split the part list by 25 rows. It's mean that code will create 4 sheets and copy part list to all sheets. Than hide the unwanted rows automatically. For example the code will hide row-26 between row-100 in first sheet. And the code will hide in second sheet row-1 between row-25 and row 51 between row 100 etc...
I will share this code here when I finished it... I think we need to find extra solutions like VB code untill Autodesk confirm our demands unfortunatelly 😞
Mucip:)
THE existing wrapping scheme doesn't work for us as we put the parts list above the title block. So when we use the wrapping option the second column leaves a large gap below it. That's wasted space that I need for the list. It would cause me a lot of the time, for those last few components to wrap a third column unnecessarily or more likly add to second sheet
MSK
I send you one sample part catalogue section of our machines attached. As you see the part list may be 3-4 pages long. And It's necessary to split part list after tha drawing sheet. This is standart manufacturing process...
Mucip:)
Is there a way to make the parts list break unevenly? For example, if I had a 40 row high column, hoe could I break it at 25 and 5, instead of 20 and 20? The only workaround I know of is to create another parts list and toggling rows visible or hidden.
In the parts list, if you right click on a row you can toggle the wrap.
Now it might not remember "25 and 5" if you go messing around adding or removing parts so be prepared to fiddle with it if you're still changing things.
Go check out Solid Edge I don't like the software much but it has a few things Autodesk should have done years ago.
I really like how the parts list is done for long parts list.
In Solid Edge all you have to do is tell int how tall you want the parts list and it breaks it up. Let say you make it 18 inch tall part list but the list is 36 it will make two list 18 inches tall then if you want the 2nd list on another page you right click on it and tell it what sheet to go on.
I love this in Solid Edge and it is almost the only thing LOL....
Yes... Inventor should have this feature long time ago...
As I see the Inventor versions, programmers add only visual effects/features. They should listen us and add the features which real users want...
Mucip:)
Buy about 300 million shares in stock and you can make the calls... I am sick of watching Inventor turn into a Max or Biz program.
I wish they would fire the Solid Works guy they hired he is destroying Inventor...
First is a standard split parts list, wasted space under split.
Second is using 2 parts lists and using visibility of components, no wasted space. I have 101 parts and it just barely fits using the 2 parts list method, otherwise it would take a additional sheet for the parts list.
Splitting parts lists is a big waste for long pats lists. I would lose about 12 components in second column.
MSK
Wrap table is within the parts list editor and split table is done by right clicking on a row in the drawing.
It's almost like if they made a car that you turn with a steering wheel, but it only turned to the left - so when they add right turns, you have to push a button under the seat instead.
