Inventor General Discussion
Member
crepps
Message 11 of 18 (631 Views)
Re: Parts List Break
08-14-2012 08:04 AM in reply to: swimfast831
Is there a way to make the parts list break unevenly? For example, if I had a 40 row high column, hoe could I break it at 25 and 5, instead of 20 and 20?  The only workaround I know of is to create another parts list and toggling rows visible or hidden.
Office Laptop specs:
- Inventor Professional 2012 (Autodesk Product Design Suite)
- Dell Precision M6600
- Intel i7-2960XM @ 2.70GHz
- 8GB RAM
- 128GB mSATA SSD (main)
- (2) 750GB drives (non-RAID)
- touchscreen display w/ pen
- Windows 7 Ultimate
Home Laptop specs:
- Dell XPS 17 (non-3D version)
- Intel i7 2nd gen
- 16GB RAM
- (2) 500GB drives (non-RAID)
- AutoCAD Mechanical 2008 (Retail License)
- entire Audodesk product line (Student Licenses)
- Google SketchUp 8 (Retail License)
- Blender
- Cinema 4D
- various other design software packages
dan_inv09
Message 12 of 18 (629 Views)
08-14-2012 08:09 AM in reply to: crepps
In the parts list, if you right click on a row you can toggle the wrap.
Now it might not remember "25 and 5" if you go messing around adding or removing parts so be prepared to fiddle with it if you're still changing things.
*Pro
jletcher
Message 13 of 18 (626 Views)
08-14-2012 08:27 AM in reply to: mucip
Go check out Solid Edge I don't like the software much but it has a few things Autodesk should have done years ago.
I really like how the parts list is done for long parts list.
In Solid Edge all you have to do is tell int how tall you want the parts list and it breaks it up. Let say you make it 18 inch tall part list but the list is 36 it will make two list 18 inches tall then if you want the 2nd list on another page you right click on it and tell it what sheet to go on.
I love this in Solid Edge and it is almost the only thing LOL....
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
Distinguished Contributor
mucip
Message 14 of 18 (620 Views)
08-14-2012 12:44 PM in reply to: crepps
Yes... Inventor should have this feature long time ago...
As I see the Inventor versions, programmers add only visual effects/features. They should listen us and add the features which real users want...
Mucip:smileyhappy:
*Pro
jletcher
Message 15 of 18 (616 Views)
08-14-2012 01:14 PM in reply to: mucip
Buy about 300 million shares in stock and you can make the calls... I am sick of watching Inventor turn into a Max or Biz program.
I wish they would fire the Solid Works guy they hired he is destroying Inventor...
James Letcher
msklein
Message 16 of 18 (607 Views)
08-14-2012 02:44 PM in reply to: crepps
First is a standard split parts list, wasted space under split.
Second is using 2 parts lists and using visibility of components, no wasted space. I have 101 parts and it just barely fits using the 2 parts list method, otherwise it would take  a additional sheet for the parts list.
Splitting parts lists is a big waste for long pats lists. I would lose about 12 components in second column.
MSK
Valued Mentor
stephengibson76
Message 17 of 18 (454 Views)
08-23-2013 02:18 AM in reply to: msklein
not sure which release this came in but 2014, RMB on the parts list, table, split table seems to work as required... not tested but initial kudos to autodesk
Stephen Gibson
View stephen gibson's profile on LinkedIn
dan_inv09
Message 18 of 18 (439 Views)
08-23-2013 04:10 PM in reply to: stephengibson76
Wrap table is within the parts list editor and split table is done by right clicking on a row in the drawing.
It's almost like if they made a car that you turn with a steering wheel, but it only turned to the left - so when they add right turns, you have to push a button under the seat instead.
