Well the 'required' column is easy, just go into the column chooser and
create a custom column. This can be done in your master template and it
will then be available to add to the PL in all dwgs. As far as making
the quantity automatic, haven't got a clue there.
DonA wrote:
> Hal,
> You make a good point.
> In my particular case I use inventor to design molds.
> Molds, can be considered as "one unit" consisting of many components. In
> some case, some components are all the same. Such as 4 Cavities, 4 guide
> pins, 12 core pins style A, 48 core pins style B, 2 runner blocks, and
> so on.
> It is customary to have the "qty" (Amount required))show for each
> component in the assembly. However, each of the individual components
> within the assembly may go to different moldmakers for manufacturer, and
> the assembly drawing is not always at their disposal, as well It may not
> need be.
> In this case the "qty" needs to "tag along" with the detail drawing. In
> reality a "required" column is really whats needed to tag along with the
> detail. Then a "Manual Qty to make" column could be used/added on the
> detail sheet. The default would be to make the "required" if the "Qty"
> colum were left blank.
> In any event what I am really looking for then is a change in
> terminology. "Required" would be more appropriate, and which is what I
> would want to be the same on the assembly as well as the detail sheet...
> again "Automatic" and automatically updatable on both.
> Anyway that that can be accompolihed works for me.
> Regards,
> and THANKS,
> Don A 🙂
Hal Gwin
Mechanical Designer
Xenogen
W2K SP4
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4472 w/registry update
Dell UltraSharp 19" LCD
