Inventor Forum
parts Library
4 REPLIES 4
124 Views, 4 Replies
parts Library
I just loaded inventer 6 on my D drive.I can not get the standard partd library to showup. I click the model button; but, it only shows model.
Thanks Chris
4 REPLIES 4
Are you in Part or Assembly Mode? It only shows up in Assembly Mode.
Dave Jacquemotte
Automation Designer
In assembly mode all I get is catalogs. Standard parts does not showup
Thanks Chris
Do you see a drop down option that says Library? Click on that. This will take
you to the Parts Library. (Not to be confused with the Library Path in Project
File.)
Dave Jacquemotte
Automation Designer
rmitch
I had this on my system. It was caused by having IV5 and IV6 on the same machine. I opened IV5 and found the Autodesk i-drop Translator was included as as an Add-in to IV5. Closing IV5 and restarting IV6 (which I believe re-registered) cured the problem
Roger Mitchell
