Guys
Concerning Inventor 2012...
We do a good bit of deriving parts from assemblies. We have a workflow that works well for us, we create PARTS, put them in an ASSEMBLY, then create new PARTS DERIVED from ASSEMBLY. We use Boolean to add/subtract and disregard parts as needed to create these parts. These parts are now given color and reassembled in an yet another final ASSEMBLY as needed and put into a drawing.
Through Inventor 2011 this worked well.
In Inventor 2012 the color is disapering as soon as any change is made on a source part.
1 Changing the color does not work.
2 In the derived from Assembly, opening up (in the browser) the individual .ipt's and right clicking and clicking properties and changing the color only stays until the next change to the source prt.
3 Changing EACH individual face by right click, properties and setting the FACE PROPERTIES from "as feature" to "as part" does work, but is ridiculous to change hundreds of faces on each part. (especially considering we did NOT need this step in 2011)
Please Autodesk - HELP!!! Is there a switch in the registry (to turn off the standard “as feature” to the parts face) or somewhere to help us out with this problem?
Thanks to all / any in advance.
Johnson
It has been quite a while now and no word from you.
Is there a fix available and I am unaware. I do not get on the discussion groups often.
I just received 2013 and I am hesitant to even try.
Does this help Barry http://designandmotion.net/autodesk/mfg-pages/inventor/dreaded-use-color-override-source-component-a...
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Johnson, or other AUTODESK EMPLOYEE,
I see you have confirmed this problem and stated it as unexected behavior, and I have heard nothing. Any help fixing this?
Every time I make parts derived from assemblies as explained previously, I have to select and right click each face (through properties) of every final part that is visible so it shows properly on the drawing.
Please help. I am not a programer and cannot repair this myself. I simply need Inventor to work properly the way it did two years ago.
Best regards (still...)
Barry
Barry,
I have confirmed the behavior. This is indeed an unexpected behavior starting from R2011 SP1. I believe the issue you describe here is identical to the one Scott mentioned. I am working with engineering team to see how we can correct the behavior.
Many thanks for bring this issue to our attention!
Please all be aware, that this problem still exists with Inventor 2016.
If you are stuck just as i was here is the SOLUTION: when in derive window, go to representation and select your Design View and set it to MASTER.
That's it problem solved!!!
