style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"brian r. iwaskewycz" <
href="mailto:biwaskewycz@REMOVETHIS.corefurnace.com">biwaskewycz@REMOVETHIS.corefurnace.com>
wrote in message
href="news:6179705@discussion.autodesk.com">news:6179705@discussion.autodesk.com...
I've got a spherical roller bearing, inserted
from the Content Center as a custom part (i.e., it's in the project's folder,
not the CC folder, so it's modifiable). The Modeling tab of the
bearing's Document Settings has "Participate in Assembly and Drawing Sections"
checked. It's placed into an assembly with a shaft, bearing housing,
etc., the assembly is in a half-section view, but yet the bearing does not get
sectioned. The entire bearing is visible. I must be losing my
mind.
Inventor 2009 Pro SP2.
brian
r. iwaskewycz
style="FONT-SIZE: 14pt; FONT-FAMILY: Verdana">inventor
specialist
style="FONT-SIZE: 14pt; FONT-FAMILY: Verdana">core furnace
systems
wrote in message
href="news:6179953@discussion.autodesk.com">news:6179953@discussion.autodesk.com...
This isn't a drawing, Patrick. It's an
assembly.
brian
r. iwaskewycz
specialist
systems
<HallStevenson> wrote in message>
href="news:6180056@discussion.autodesk.com">news:6180056@discussion.autodesk.com...
{quote:title=Guest wrote:}{quote} >
> >Patrick, having that checked does not, in my experience, have any
Oops, my bad. I focused right in on the "drawing">
> part of the option. Did the "Application Options > Assembly tab >
Section > all parts" fix this (that Hall mentioned)?
implications to IDWs or drawings. From your earlier post, you pointed to the
"Document Settings" option for sectioning a part in a drawing. Is that what
controls it ? If so, that's a huge mistake. Users shouldn't, and typically
can't, edit CC parts. I realize that you're not actually changing the model,
but I'm positive that Inventor is going to see turning this on as a change and
prompt you to save it. Regardless, I do NOT open CC parts
individually.
Inventor 2012
Assembly
Combining two assemblies into a larger assembly.
Dear all,
I understand that this thread is a bit old, but I am having an issue associated with this.
Working in an assembly I am trying to section specific parts only.
The core problem is that in: Tools - Document Settings - Modelling Tab - the 'Participate in assembly and drawing section' is not visible?
Any ideas how I can get it back?
Alex
