Inventor Forum
Participate in Assembly and Drawing section - Inventor 2015 Bug?
6 REPLIES 6
saseendrankombath
771 Views, 6 Replies
Participate in Assembly and drawing Section turned to True after reopen the document.
Created a Part, change the Participate in Assembly and drawing section (Checked removed), Saved the Document. It remains the same until I close the document. If I open The same document again, it is with Participate in assembly and drawing section checked.
I also tried the same using API. by using oPart.ModelingSettings.AllowSectioningThruPart=False , Save and close the document. If Open the same document again and check the status shows oPart.ModelingSettings.AllowSectioningThruPart as True.
Same behavior after installing Update -1
Hope Autodesk will respond to this post.
Autodesk Product Design Suit Ultimate 2015
Autodesk Inventor Professional 2015 64Bit Edition
Build:159, Release: 2015 RTM Update 1- date 05/12/2014
6 REPLIES 6
I confirm, same behavior.
The setting autoself check itself.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
No suggestion from Autodesk?
t_pcoll
in reply to: saseendrankombath
i did try quick test and it looked to work for me.. Can you please send me the part so I can double check? (ladislav(dot)pcola(at)autodesk.com)
Ladislav
t_pcoll
in reply to: t_pcoll
I'm sorry I now see the issue. Thanks for reporting!
Ladislav
t_pcoll
it looks to me that saving the IPT using Save Copy As is not affected by the problem - please try use Save Copy As as a workaround when its needed to uncheck the option.
I hope this helps.
Ladislav
saseendrankombath
Thanks Ladislav,
As a workaround save copy as works fine but, When ever we do some modification then we have to create a new copy of the same with a new name and then replace the old one with the new in the assembly. This takes more time. Currently we modify the drawing by changing the section behavior from the browser node.
Is there any method to save copy with the same name in the same folder? (manually or thru API)
Hope Autodesk will come up with a Hotfix or Update on this problem.
Saseendran Kombath
